Funk skrev:Det skall tydligen inte heller vara någon fara att låta det torka in...
Enligt texten kan man låta det torka in helt innan man spolar av det..
Saxat från en UK sida där dom säljer detta!..
DIRECTIONS:
Apply an even coat of Brake Duster to the entire rim and let stand until the
iron particles have completely dissolved or until the cleaner is completely dry. Once it has turned a dark purple color or has formed a hard shell on the wheel,
rinse clean with a pressure washer. If using without a pressure washer,
rinse before it dries for best results. On more contaminated wheels, some agitation may be required.
Gel Wheel Cleaner - The Brake Duster
Product code: WOC-WF-1P-5L
