Sida 1 av 2
Billig Rain Repellent som alla bilentusiaster har!
Postat: 16 jun 2013 21:47
av Alan43
Har gjort en video och laddat upp på youtube om hur ni förbereder en framruta för att motstå regn på ett optimalt sätt utan att behöva applicera varken Rain X Repellent eller Aquapel. Kika gärna på videon och kommentera!
http://www.youtube.com/watch?v=G0bDjZw- ... e=youtu.be
Re: Billig Rain Repellent som alla bilentusiaster har!
Postat: 16 jun 2013 21:59
av JesperNilsson
Hur länge håller det där då..?
Postat: 16 jun 2013 22:01
av Alan43
Länge!!! Har gjort detta innan och av erfarenhet cirka 2 månader.
Postat: 16 jun 2013 22:04
av JesperNilsson
Har en aquapel hemma som jag ska testa först
Sv: Billig Rain Repellent som alla bilentusiaster har!
Postat: 16 jun 2013 22:38
av Jimmy Larsson
Vad har du gjort?
Postat: 16 jun 2013 22:45
Jimmy Larsson
Detta.
Prior to applying the Armor All Extreme Shield Wax to my windshield I first cleaned it thoroughly. I used a car glass cleaner from Autoglym (Fast Glass) to remove all the dirt and insects from the windshield followed by a highly effective glass polisher from Autoglym to remove light scratches and other contaminants which the aforementioned car glass cleaner failed to remove. Finally, after I wiped off the residue meticulously I used a very small amount of the Armor All Shield Extreme Wax and applied it onto the windshield. I removed the residue immediately according to the manufacturer's instructions. This step is very important. Apply only a small amount of wax and wipe it off immediately. Make sure that there is no residue left on the windshield. Also, clean your wiper blades thoroughly as the application of wax or sealants might interfere with your wipers' ability to function properly. If you use too much wax rest assured that this will impair the ability of your wipers to clean your windshield thoroughly. Use a pea-sized amount of wax for the entire windscreen. What is good about this method is that it is rather inexpensive and most of us car enthusiasts have a car wax readily available on a shelf. A word of warning though: I have come across instances when the use of wax on a windscreen dramatically impaired the functionality of wipers to a degree when visibility became a serious issue. Never ever apply anything on your windscreen unless you know what you are doing!
Kategori
Bilar och fordon
Licens
Standardlicens för YouTube
Postat: 16 jun 2013 22:46
av JesperNilsson
Alltså typ lagt på vax på rutan?
Postat: 16 jun 2013 22:48
JesperNilsson
Förenklat svar ja.
Postat: 16 jun 2013 22:50
av Rednales
JesperNilsson skrev:Alltså typ lagt på vax på rutan?
Japp. Håller mig nog till beprövade produkter på vindrutan. Brukar lägga lackskyddet jag använder för tillfället till sidorutor utan problem men till framrutan kan jag lika gärna kosta på lite rutsmörja (finns ju väldigt billig sådan också).
Postat: 16 jun 2013 23:17
av JesperNilsson
Har kört med biltemas rain off , vet dock inte om den finns kvar i deras sortiment? Men den har fungerat fint ! Men alltid kul med nya tips!
Postat: 17 jun 2013 09:38
av Andyah
JesperNilsson skrev:Har kört med biltemas rain off , vet dock inte om den finns kvar i deras sortiment? Men den har fungerat fint ! Men alltid kul med nya tips!
den finns..men dom gjort om flaskan.
http://biltema.se/sv/Bilvard/Exterior-r ... lent-3640/
Postat: 17 jun 2013 13:50
av JesperNilsson
Och ändrat namn
Postat: 08 jul 2013 20:54
Har kört Aquapel på samtliga rutor i många år och tänker fortsätta med det. Två behandlingar av vindrutan varje år är lagom.
Postat: 08 jul 2013 21:50
Perra83 skrev:Har kört Aquapel på samtliga rutor i många år och tänker fortsätta med det. Två behandlingar av vindrutan varje år är lagom.
Min Aquapelbehandlade vindruta har nu fungerat i 2,5 år utan upprepad behandling.
Jag använder sällan vindrutetorkarna och "aldrig" spolarvätska...det är väl det som gör att behandlingen har fungerat så länge.
Varför fungerar det bara i 6 månader för dig per behandling?
Postat: 08 jul 2013 22:01
av miken
Manor skrev:Perra83 skrev:Har kört Aquapel på samtliga rutor i många år och tänker fortsätta med det. Två behandlingar av vindrutan varje år är lagom.
Låter otroligt att du fått det att hålla i 2,5 år
För mig håller en Aquapel behandling cirka 12 månader ungefär 1000mil men då är avrinningen väldigt dålig i slutet men det tycker jag är fullt godkänt
Postat: 08 jul 2013 22:10
av jonkegtx
Min Aquapel höll i ca 2000 mil, på en bil som alltid står ute och körs mycket. (500mil/mån)
Så för mig hade det behövts 2-3 Aquapelbehandlingar per år
Postat: 08 jul 2013 22:13
av Lemerok
Bekvämligheten med Orchard Hydrophobe är svår att slå! Testas på min bil nu med.
Postat: 08 jul 2013 22:44
av jonkegtx
Kul att höra Lemerok
Postat: 08 jul 2013 23:11
Ja vill ha som nybehandlat hela tiden. På tjejens C30 så har ja nog bara behandlat vindrutan en gång... och det är ett år sedan... Dags nu igen i alla fall. Sidorutorna håller nog flera år.
När man använder dieselvärmaren på vintern så rinner is och snö av väldigt lätt.
Postat: 08 jul 2013 23:54
Har gjort ett litet annorlunda test
Vid sovrums fönstret är det 2 fönster med ram mellan
Maskera halva rutan på mitten
på rutan tog jag biltema vax
andra turtle nano lackförsegling
och så här långt står dom sig väldigt lika och det märkt ju väldig skillnad då det regnar på lite
nu är det ju inga torkarblad som sliter på detta, Men båda har stått emot stark sol i 2månader nu o inne på 3'dje
Om man tänker på både bilar och husfönster så vet jag inte om det gör till eller från i lättheten att hålla rent.
